1 members (pauld),
115
Mod | | | Forums66 Topics128,265 Posts1,058,366 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 22 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 22 | ON my 59 Apache with a 235 6 cyl. and a remote oil filter. The Oil lines in & out are bad. The parts catalogs don't show any, one place had some but had wrong fittings on the ends. Better off trying to have some made ?? Hate to use a hose barb style fitting and a hose clamp.....
Any help.....
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Got mine from National Chevy Association Parts. Chevy of the 40's also carries them in their oiling section. Around $35.00-$40.00 per set.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2015 Posts: 22 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 22 | Tim...
Thanks for all your help.
Tobtub59
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Another alternative would be to take your original hoses to a Napa, Tractor Supply, or any other place you might have locally that makes hydraulic lines. They should be able to make you a set with the correct ends and length, and could possibly be less expensive.
Bill Burmeister | | | | | Joined: Sep 2010 Posts: 1,732 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,732 | I made my own with hard brake lines and a couple of fittings from my Ace Hardware. Spent about $12. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | I also did the same as Wayne, Coated brake lines from Napa, The look great too. | | |
