1 members (Bill Hanlon), 138 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#1087249 02/22/2015 5:18 PM
Hello, I am planning on putting disc brakes on all four wheels of my '53 3100. I am thinking of keeping the brakes manual and would like to use the stock pedals (clutch and brake pedal). What do I need to use for a master cylinder? It is my understanding that I need a dual chamber mc. If so, is there a dual chamber mc that will bolt in the original mounts, or will I need an adaptor bracket of some sort? Will I need a prop valve or any other device inline so the brakes work properly? Any pictures or part numbers from setups like this would be appreciated. Thank you.
3B Offline
Hy Lemmm117, I would not recommend manual disc brakes, your pedal effort would be excessive. There are kits available to mount the master cylinder/booster under the floor and use your stock pedals. You will need to order a master cylinder for a disc/disc application (no residual pressure valves), and yes a proportioning valve is required. If you search for CPP and other suppliers of brake conversion kits you'll find a lot to choose from, hope that helps.
Lemmm117 I have 49 3100 and I am going to be adding Disc Brakes to my truck too. I too am going to go with Manual brakes on my truck as well. I am not to the point of actually putting parts on my truck ( I have a son that would like to go to college first, kids!). Any ways I was figuring that I would use the master cylinder from an early 70's half ton truck with the Disc / Drum setup. I do know that will need a bracket to use the original pedals. I believe that most of the suppliers offer this bracket. I also believe that you will need a proportioning valve and possibly something else, but my mind isn't working right now.
Good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Gas Pumper
Gas Pumper
You can check out the Site Picture Archive at devestechnet.com for pics of that setup. I went with manual front disc, rear Bendix drum on my 50 project.
The problem with power was having to change or modify the crossmember. I also didnt want to move the MC to the firewall. It will be years before I am ready to test it, but others have manual front discs and are happy with the setup.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Bear in mind, disk brakes are not self energizing like the original Bendix Duo-Servo brakes found on the '53. Brake pedal effort will be higher than with the drums.
Bill Burmeister
I am converting mine to disc/drum with the Hollister kit sold here on the forum. I found 2011 CHEV 1 ton express van rotors and calipers with all mounting hardware. I then purchased this unit per the recommendation of Hollister and other members. I also got the remote filler/reservoir and tool for the proportioning valve. It mounts in the stock location and uses the stock pedals. It only cost a few more dollars to do it the right way first!
SKU Product Item price Quantity Total
BB2-T4755 1947-55 Chevy-GMC Truck Power Brake Booster Kit
Options: Brakes: 2 Wheel Disc
Prop Valve Tool: Yes(PvBT)
Remote Fill Kit: Yes(RRCK)
$392.98
