7 members (MNSmith, Tyler Watts, porsche, Bill Hanlon, Barnfind49, Stovebolt48, 1 invisible),
102
Mod | | | Forums66 Topics128,277 Posts1,058,456 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | Hello, I am planning on putting disc brakes on all four wheels of my '53 3100. I am thinking of keeping the brakes manual and would like to use the stock pedals (clutch and brake pedal). What do I need to use for a master cylinder? It is my understanding that I need a dual chamber mc. If so, is there a dual chamber mc that will bolt in the original mounts, or will I need an adaptor bracket of some sort? Will I need a prop valve or any other device inline so the brakes work properly? Any pictures or part numbers from setups like this would be appreciated. Thank you. | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Lemmm117, I would not recommend manual disc brakes, your pedal effort would be excessive. There are kits available to mount the master cylinder/booster under the floor and use your stock pedals. You will need to order a master cylinder for a disc/disc application (no residual pressure valves), and yes a proportioning valve is required. If you search for CPP and other suppliers of brake conversion kits you'll find a lot to choose from, hope that helps. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Lemmm117 I have 49 3100 and I am going to be adding Disc Brakes to my truck too. I too am going to go with Manual brakes on my truck as well. I am not to the point of actually putting parts on my truck ( I have a son that would like to go to college first, kids!). Any ways I was figuring that I would use the master cylinder from an early 70's half ton truck with the Disc / Drum setup. I do know that will need a bracket to use the original pedals. I believe that most of the suppliers offer this bracket. I also believe that you will need a proportioning valve and possibly something else, but my mind isn't working right now.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | You can check out the Site Picture Archive at devestechnet.com for pics of that setup. I went with manual front disc, rear Bendix drum on my 50 project.
The problem with power was having to change or modify the crossmember. I also didnt want to move the MC to the firewall. It will be years before I am ready to test it, but others have manual front discs and are happy with the setup. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Bear in mind, disk brakes are not self energizing like the original Bendix Duo-Servo brakes found on the '53. Brake pedal effort will be higher than with the drums.
Bill Burmeister | | | | | Joined: Aug 2011 Posts: 229 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 229 | I am converting mine to disc/drum with the Hollister kit sold here on the forum. I found 2011 CHEV 1 ton express van rotors and calipers with all mounting hardware. I then purchased this unit per the recommendation of Hollister and other members. I also got the remote filler/reservoir and tool for the proportioning valve. It mounts in the stock location and uses the stock pedals. It only cost a few more dollars to do it the right way first!
SKU Product Item price Quantity Total BB2-T4755 1947-55 Chevy-GMC Truck Power Brake Booster Kit Options: Brakes: 2 Wheel Disc Prop Valve Tool: Yes(PvBT) Remote Fill Kit: Yes(RRCK) $392.98 | | |
