| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | A friend of mine has a 3/4 ton with a 2 speed powerglide transmission. He says it's a factory built. Did Chevy make an automatic 54 with a powerglide? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No 1954 truck came from the factory with a Powerglide.
The 2-speed Powerglide was used in cars starting in 1950. It was used in trucks sometime around 1959/60.
In 1954, the only automatic transmission was the 4-speed Hydra-Matic. Most likely, that is what you friend is referring to?
