2 members (2-Ton, Peggy M), 151 guests, and 2 robots.
Topics128,105
Posts1,056,538
Members48,448
#1086525 02/19/2015 12:42 AM
anyone have a picture of where the oil filter lines go into the block on a 1956 235? mine has a few different plugs and I dont know which one to use for my oil pressure gauge/filter line
Sir Searchalot
Sir Searchalot
Found on Stovebolt search http://www.1954advance-design.com/Documents/53%20AC%20Oil%20Filter%20Install.pdf
Real nice hook up instruction in our tech tip section: Engine/Oil Filters/Instructions Pat Doonan.
Here is a closer and maybe a clearer photo of where the lines connect to the block.
The oil-pressure sender line connects to a brass T-fitting where the filter-inlet lines goes into the block (as shown in the installation diagram).
