13 members (Gdads51, Rusty Heaps, FishinToms53, MNSmith, NAPCOStormTrpr, Jon G, Otto Skorzeny, Cletus1950, Peggy M, Shaffer's1950, Leo, GDW, Hanks custodian), 99 guests, and 0 robots.
Topics128,139
Posts1,056,455
Members48,441
#108642 03/18/2004 1:23 PM
8
8 Offline
I want to replace the wooden floor in my 50 suburban. I want to go back with a stronger wood than was there. Is there anyway to take the original floor out intact so I can make a pattern for the new floor. The best I can tell from how it's bolted in is that it has to come from the bottom. Thanks in advance for any info.....
Anthony McCants
1950 Chevy Suburban
#108643 03/18/2004 2:05 PM
89cutlass,
I am not sure that all 1947.5-1955.5 Suburban rear floors are the same. If your suburban floor is a single piece of plywood (as it is in 1954), it can only be removed (in one piece) in an upward direction. The sidewals below the floor curve inwards and prevent removal in a downwards direction.
You will have to remove the right-angled retainer (ledge) from one side of the interior. This is spot-welded directly aboove the floor (at least 28 spot welds). With the retainer removed from one side, the floor can be angled upwards and removed. I have never done this but have talked with two other people who have.
You say you want to go with a stronger wood - that plywood seems quite strong (if you have plywood).
Tim
#108644 03/27/2004 6:19 AM
I just went through this last weekend on my 54. Once I got the retainer from the right side off, I found it near impossible to lift it out. It was binding on the other side. Solution, I took my circular saw right down the middle. I still have my wood for the template.
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2002 Chevy 1500 4X4
"Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it."
Thomas Paine, The American Crisis, No. 4, September 11, 1777
#108645 03/27/2004 6:19 PM
Releasing the bonded side might be assisted by heating the metal lip (I used a heat gun) while sliding at thin putty knife under the metal edge. Mine dropped free of the metal edge.
Tim
#108646 04/18/2004 8:45 PM
89cutlass,
Prior to sending my 48 Suburban to Redi-Strip I removed my wood floor like 3100 did - cut it straight down the middle and took the halves out. The two halves make an excellent patern. The plywood used was/is 5/8" marine grade which can be found in a sheet large enough for 1 piece replacement(the price to buy and have it shipped to you might cause you some discomfort) for those who take out the welded on side angles. To reinstall after cutting out in two pieces get two sheets 5/8" a/c(this grade has fewer voids than less expensive grades) plywood, oak if you like, route and join the centers(factory edges) with a hardwood floor spline and glue. I highly recommend dry fitting prior to the glue and spline and install. A couple of handy friends around help also! The "brackets" for mounting original seats can ge routed out and installed after the plywood floor has been installed. Once the wood is in and the underfloor cross sills have been installed the floor should be plenty sturdy.
JohnRJoyner
48 Suburban,55 1st 1/2 ton, 53 GMC
