7 members (HandyAndy, 68ironhead, Rexville48, walter74, 6inarow, GMCJammer51, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,567 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | I am trying to do a factory original 1950 Chevrolet 3100 5 window as close to factory specs as possible. Would any one know about under the fenders and under the hood if they were body colour or just black Painted? Also under side of body. I am doing truck in Swifts red. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | On my '52, I had forester green paint on the underside of front fenders toward the rear where road tar had covered and preserved it. It was not over-spray, in my opinion. Carl
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | My '51 3100 is two tone black and green . It has black fenders which is sprayed on the underside of the fender and the hood is Forester Green which has the same green sprayed on the underside. | | | | | Joined: Mar 2010 Posts: 6 New Guy | | New Guy Joined: Mar 2010 Posts: 6 | Pete According to the V.C.C.A. Literature & tech advisor. Forester Green (PPG-40509) is exterior body except running boards. Under fenders/wheel wells semi-black/chassis black Under hood semi-black Please correct me if this is inaccurate. thank you in advance. D@C
1951 Chevy 1/2 pu Restoration/stock Deluxe Cab Five window
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No Dave, you need no correction. Why would the Chevrolet factory bother finish painting the underside of any body parts on a work truck. These were not custom made trucks, there were some options but painting the under body was not one of them. If the underside of your hood, fenders, etc. is painted the same as the body then the truck has had work done to it some time after it left the factory. The body panels were black semi gloss e-coated primer. Some were painted right over the e-coat and some had a red oxide primer coat. I've never seen any documentation as to which factory, shift or paint line primed the trucks. The cars were primed glazed and sanded which there are photos of this being done. I've not seen photos of any trucks running through the paint lines. You'll find over spray only under the fenders, hood, running board where they painted the edges on an original factory paint job. Under the cab there was some undercoating applied, it was applied after the cab was mounted, it was not the entire bottom. If the bottom of the cab was painted, I've never seen an example where any paint remained. There would have been a swipe of undercoat under the fenders where mud, stones, grit and grime could be thrown up by the tires. I've see original examples where the box sides had been painted with the standard green prior to assembly of the rear fenders. Optional colors seem to have been applied after the box was assembled with the fenders in place. Like to hear from Brad Allen on this also. He probably has a better feel for the original factory paint schedule than anyone on the forum since he has parted out many many AD's and is a stickler for the documentation.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | My original paint on the GMC was; E-coat, Red Oxide and then top coated. There is plenty of evidence from the wear-thru of the patina created. This combination has held up well for 65+ years. It will also remain the trucks paint scheme.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
