| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 13 New Guy | | New Guy Joined: Apr 2012 Posts: 13 | I have a '63 GMC with the frame around the door windows. I'm replacing the window channel that goes in the top and rear of the door. The original was corrugated metal with mohair fabric around it. Mine had clips cross-ways to the window channel that popped into the door frame. The repro channel doesn't have these clips. How do you secure the new channel to the door frame? do they just push in? do you screw it to the frame? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Welcome to the pages. Maybe it depends on the years and I am not entirely sure. Maybe someone else can verify. On my 62 the channel was supported by a metal frame. I pushed it into the door frame and it stays without fastening. Rolled window up to set the top edge. On my 66 the seal was just the rubber, felted material and I pressed it into the door channel no problems. It stays put. Sounds like you have the material of my 66. | | | | | Joined: Oct 2011 Posts: 20 New Guy | | New Guy Joined: Oct 2011 Posts: 20 | I remember doing that with my truck awhile back with a LMC kit. I put a little silicone adhesive in the corner and rolled the window up to set it in place. The window was extreamly difficult to roll up and down due to being too tight. Had to teak it a bit to work right. BTW, thanks for the reply on the front brakes. I figured it was original but wasn't 100% sure | | |
