3 members (TexasA&M48Truck, UtahYork, 1 invisible), 55 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
Pulled my tranny to install a new clutch and find the flywheel has some hair line cracks radiating out from center to about a half inch and a few what I think might be stress cracks about a 1/4 inch long in various places around the disk surface. Can I just have it turned down by a machine shop to clean up the surface? or do I really need to get a replacement. If I need to replace it where do I get one - Ebay? . Does someone sell new ones?
Thanks Craig
Still trying to get ole Betsy back on the road.
Unless the cracks are gapped open a bunch, just have it ground flat, deep enough to get rid of any glazed areas. Minor heat checks don't usually give a problem unless the flywheel is being abused by high RPM launches and kamikaze clutch dumps.
Hotrod,Thanks. No real big cracks just some hairline looking stuff so I'm going to take it and have it surfaced per your recommendation. Thanks
well just be careful, I had the same situation, and after about 3000 miles I took the engine BACK OUT because of an itty bitty leak in the one soft plug you can't reach with the engine in place. Whereupon I discovered the flywheel I had installed with the tiny little hairline cracks as described above, had turned into major fissures. Which explained the chattering I had developed. It turned out the water leak was a good thing after all.
Brokenhead, thanks for the tip. I'll keep an ear open for a chatter. I'd go for a new flywheel but can't find a supplier. Everything I see is for small block chevy's. Used stuff on eBay is probably worse that what I already have. Thanks again for the response.
Got the flywheel back today and it looks like new. Machine shop did a real nice job. They also said all the hairline fisures were just superficial and now they are all gone. Now if I can find some of the bolt retainers I can reinstall it and be good to go. Thanks for the tips and advice guys.
I would skip the bent locks. Use a good external star washer and a bit of Loctite on the threads. The bolts won't come loose and you can still get them out if needed.
Steve H
I thought that the bolt heads also sealed the holes so that oil didn't come through from the crankcase. Is that correct?
1951 1 Ton Completed
Yes- - -my 59 3800 came to me with one flywheel bolt missing, and a massive oil leak that ruined the clutch. The PO who "rebuilt" it before he sold it to me cross-threaded a flywheel bolt and then left it out. A star washer or a split lock washer would be a bad idea.
Loctite on the threads also makes a good oil seal.
