0 members (),
75
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 84 | I have a 1950 3100 and would like to replace the wood for the bed, everything I see show 9 boards for the bed however the bed in it now has 7 boards, I saw the 1946 bed had 7 boards, is htere any way to tell if the bed is actually a 1950 or if it may be a 1946 bed on my 1950 truck?
Thanks for your help
1953 3100
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 7 bed boards in 1946.
9 bed boards through 1951.
8 bed boards in 1952 and later.
50" usable bed width in 1947 and later. 48.5 usable bed width in 1946.
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | You can take a look at the bed cross sills for the holes that correspond with where the bed strips are supposed to be located. If the only holes in the cross sills are the ones with the bed strip bolts in them, then you have a 46 or earlier bed parts. Carl
| | | | | Joined: Nov 2014 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 84 | Ok THanks
The bed is 50" wide I will check the hole locations, maybe some one replaced the orginal boards at some point with the 7 that are there now - All the boards are about the same width on my bed, pictures of '46 beds that I have seen appear that the center board is wider than the others
1953 3100
