| | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 13 New Guy | | New Guy Joined: Jul 2014 Posts: 13 | One of the tech articals in Stovebolt shows how to adapt 1959 pickup hubcaps to later chevy six lug rally wheels by cuting off part the rally wheel center cap and attaching the older style hubcap clips to the modified rally center cap ring. My question is: can I adapt the even earlier 1941-1946 hubcaps to rally wheels center caps the same way as the gentalman did with 1959 hubcaps? The rally wheels I have are off about a 1974 blazer and have about a 9 inch center area for the hubcap to rest on. Is there a difference between the 1959 hubcap diameter and the 1941-46 hubcap diameter as to how they attached to the orignal wheels. Any help would be greatly appreciated. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | haven't seen that tip, can you link it? all Chevy caps from 30's to 1960 have the same mounting diameter, only real difference is before 55 they used 6 clips, 55-60 used 3 clips
Bill | | | | | Joined: Jul 2010 Posts: 10 New Guy | | New Guy Joined: Jul 2010 Posts: 10 | the one tons in 52 had bigger caps. WW | | | | | Joined: Jul 2014 Posts: 13 New Guy | | New Guy Joined: Jul 2014 Posts: 13 | thanks red58. you answered my question. if it works out i will post some pictures. | | |
