5 members (BarryP, 78buckshot, Mike Roache, Gray_Ghost, 1955 1 Series), 126 guests, and 2 robots.
Topics128,162
Posts1,056,924
Members48,458
#1085273 02/12/2015 10:22 PM
going to use plastiguage to check clearance on the main bearings and possibly the rod bearings, anyone know what the maximum or minimum clearance is or where I might find that information?
No specifications, but virtually all the engines I've worked on over the past 50-something years live pretty well with oil clearances of .002" or slightly less. If you get much over .003" it's hard to maintain a film of oil between the parts unless you run very heavyweight oil. Some air-cooled engines with wide piston to cylinder clearances are the only exception, and that's more about heat expansion of the pistons than lubrication.
The 1935 Shop Manual explains how to adjust the Mains and Rods without plastigauge (it wasn't around back then).
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I learned to use a thin strip of .002" shim stock between the bearing and the crankshaft and shim the cap for a "firm drag" when the crankshaft was turned carefully, then move on to the next bearing and do the same thing.
thanks, what is the torque for the bolts?
Not sure- - -if the bolt diameter is 1/2", 80-90 ft./lbs. is about right. If they're 7/16", try 65-70.
Mains 100-110
Rods 55-60
Head 75-80
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
to avoid having to ask these questions and wait for a reply and then wonder if they are actually correct. Go to the old car manual project and they have virtually all the shop manuals online, or you can go to most of the common vendors and they can get you a paper copy, maybe even a digital. The manual is nearly essential to working on these old vehicles. Not only that they are kind of cool to see how they thought back then.
i've got the shop manual for 1934, but they don't have torque specs. in it
The torque for the rods on my 1951 216 are speced at 35 to 45 ft lbs. I would be careful going above that.
1951 1 Ton Completed
Rod bolt torque in the 50-60 ft/lb range would require a bigger diameter bolt than 3/8". That's approaching the 7/16" bolt torque range, even with Grade 8 bolts.
The engineering default clearance is .00075" to .001" per inch of journal diameter.
Originally Posted by Mike B
Mains 100-110
Rods 55-60
Head 75-80
Mike B smile
I should have noted these torque specs were found in my Motor's Manual 14th Edition (1935-51).
For some unknown reason Chevrolet didn't publish their torque requirements in their shop manual.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Here is a link to the tech articles page on the Filling Stations
website. With a reasonable explanation of their data.
www.fillingstation.com/
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
