7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP), 111 guests, and 3 robots.
Topics128,185
Posts1,057,203
Members48,465
#1085309 02/13/2015 3:08 AM
I put my new gauges in and when I tried to hook up the amp gauge it sparked a lot. I guess I didn't have it centered in the holes. So do I need to order a new one? Or is there still hope for this one.
When setting goals in life. Always aim low to avoid disappointment
If you are saying that it shorted to ground and that is now corrected, why would it be damaged? You can connect a load to the ammeter using a headlight and test for deflection. Reverse the polarity to see deflection in the other direction.
1951 1 Ton Completed
V
VEW Offline
V Offline
I recommend disconnecting the ground cable from your battery before installing your gauges.
~ Victor
1957 3100 - moved on
Amp meter is tough. Please disconnect the battery before you install and connect it. All of the current, except the starter will go through it. So if the lights are on or there is something shorted it will flow through the amp meter. It is always "hot" . Pull the cables off the battery and you should be fine.
Steve H
Thanks for the replies. I know at least one of the posts is grounded to the housing. I will try to center them in the holes
