2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#108509 01/16/2003 2:22 AM
Hello, I could use come help. What is the stuff that the people that paint motorcycles use on the bare metal. This stuff they put on all over the surface. It filles in the low spots. I think it is a two part mixture. If anyone knows the name of this product please let me know. Thanks,Greg
1951 1.5 ton 4400
#108510 01/16/2003 6:49 AM
ITS EITHER A HIGH BULID PRIMER OR A HIGH Q FINISH/ GLAZING BODY FILLER.
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
#108511 01/16/2003 3:16 PM
Are you refering to "Polyester primer"? Polyester primer is like a spray on "bondo". I like the stuff personally. Instead of applying a coat of plastic filler ("bondo") just spray a few coats of polyester primer, it is much easier to sand and finish off. Plus it can be painted over with no need for more primer or sealer.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#108512 01/16/2003 5:16 PM
MARTINSR, where can you get this "primer" and is it easy to use? also could you spray it on pitted metal to make it smooth? Thanks!
1948 GMC 250 Series Flatbed
#108513 01/16/2003 7:27 PM
#108514 01/17/2003 1:18 AM
Thanks folks. The product I have seen is applied with a plastic scraper and they start with a big blob and smear it all over the surface.
They use it on blasted and I want to use it on pitted metal.
I like the idea of the spray product.
Greg
1951 1.5 ton 4400
#108515 01/17/2003 6:45 AM
Dupont also has it the # is 2290s Dupont final-fil
DUSTY G.
