2 members (3B, baldeagle),
105
7
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Hello, I could use come help. What is the stuff that the people that paint motorcycles use on the bare metal. This stuff they put on all over the surface. It filles in the low spots. I think it is a two part mixture. If anyone knows the name of this product please let me know. Thanks,Greg
1951 1.5 ton 4400 | | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | ITS EITHER A HIGH BULID PRIMER OR A HIGH Q FINISH/ GLAZING BODY FILLER.
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Are you refering to "Polyester primer"? Polyester primer is like a spray on "bondo". I like the stuff personally. Instead of applying a coat of plastic filler ("bondo") just spray a few coats of polyester primer, it is much easier to sand and finish off. Plus it can be painted over with no need for more primer or sealer.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | MARTINSR, where can you get this "primer" and is it easy to use? also could you spray it on pitted metal to make it smooth? Thanks!
1948 GMC 250 Series Flatbed
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | Thanks folks. The product I have seen is applied with a plastic scraper and they start with a big blob and smear it all over the surface.
They use it on blasted and I want to use it on pitted metal.
I like the idea of the spray product. Greg
1951 1.5 ton 4400 | | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | Dupont also has it the # is 2290s Dupont final-fil
DUSTY G.
