5 members (Steelonsteel, Tyler Watts, RaNfLaS, rfs56trk, DadsFirstPickup), 101 guests, and 2 robots.
Topics128,048
Posts1,055,663
#1084912 02/10/2015 10:23 PM
On my 59 Apache 1/2 ton Stepside, all the info on line says it has 3.90 gears in the rear end with the 235 engine.
During driveline rebuild, counted the teeth, ring had 40 & Pinion had 10. So that s a 4.10 right ???
Really like to put some Taller gears in it, but with a 3 on the tree, afraid 1st gear will be Too tall and have to burn up my new clutch.
Am I figuring ratio wrong ???
Count again... As far as I am aware, a 4.0:1 gear was never offered. 40/10=4.
A 3 speed with overdrive will bolt in place. It is really a 4 speed transmission, but the od is either operated with a cable, or an electric solenoid. This also allows for gear splitting. The transmissions can be found used for relatively short money.
R Online: Content
The standard 3:90 gearset has 39&10, the 4:11 gearset has
37&9. An original OD equipped truck would have had an 4:11 gearset all others would be 3:90. The standard 3sp and 3sp/OD transmission 1'st gear ratio is 2:94 to 1.
I have personal knowledge of a 57 truck using the aftermarket 3:38 gearset and a 56 car using a 3:08 gearset. Both have 235 engines and perform well with the stock 3 speed trans.
I feel the best solution is the 3 sp/OD.
Fred
I agree with Fred. There was also an option 3.70 Economy gear option in '58 and '59, plus the factory 3.38 that was used on Hydramatic trucks.
The overdrive/3.90 combination works great.
Bill Burmeister
U guys were right.... its a 3.90 rear end. the guy doing the engine work miss counted the teeth on the ring. Which is Ironic, because he is missin some teeth himself !!! But that's a horse of a different Color......
