5 members (Stovebolt48, 78buckshot, Ponchogl, Shardean, dt235sd), 79 guests, and 3 robots.
Topics128,021
Posts1,055,349
Members48,420
#1084847 02/10/2015 4:28 PM
I FINALLY figured out why my speedometer worked when I spun it but not in the car. When I had the gear ratio changed it included an adjuster that the speedo cable attached to. Apparently it broke and was spinning. It may have also rounded off the end of the cable. I took it off, put on my original cable and it works! Speed may not be accurate but now I can figure out how far off it is and get a good idea of my speed. Thanks to all who offered suggestions. Now on to the next problem.
Thanks for that info, since I plan on changing out my rear end gears to 3.55 in the future. Nothing worse than completing a job and finding out it isn't finished after all.
"When I rest, I rust"
1951 3100 5 window w/ '56 235
Moderated by  ndkid275, Phak1
