| | | Forums66 Topics128,103 Posts1,056,534 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 54 Member | | Member Joined: Jun 2003 Posts: 54 | I need to do some repairs inside the cab on the floor and cab corner area. What is everyones thought on welding near the gas tank inside the cab? Some people say to remove the gas tank, others say don't worry about it. Any input would be appreciated. Thanks!
Not quite as lean Not quite as mean, but Still a Marine!
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Err on the side of caution unless you think otherwise.
If you do leave the tank in place, do not perform any hot work inside the garage or possible problems can be compounded. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Agree. Better to be safe than sorry. It's easy enough to get that tank out of the way. Then as your welding, that thought won't be hanging in the back of your head and you can just concentrate on doing good welds. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | So what are you thoughts about the gas tank pushing out through the front window?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
