2 members (Otto Skorzeny, Peggy M), 197 guests, and 4 robots.
Topics128,088
Posts1,056,124
Members48,435
Have memory lapse. I am converting my '52 from 6v to 12v. Discovered a black box whose purpose is unknown. Need help ID'ing it and purpose.
Please, one of you experts !!!!
OK. Box markings:
5157C3
Hella 12v
4rd
960388-06
15591178
Also has markings showing switches. Can't draw these on here.
Hella website no help. spent 45 min. looking.
It sounds like a relay that did not come stock on your truck.
Discontinued relay for AC. This what it looks like?
http://www.gmpartscenter.net/oe-gm/15591178
Steve H
It's a simple Bosch-style cube relay that can be used as a headlight relay, fuel pump, cooling fan, fog light, or any other device that needs to be turned on/off remotely. The advantage is in using a small-gauge wire from a control switch to operate a heavy-current accessory without running the current a long way to the dash and back.
Most of the relays with a cube housing with 1" dimensions have a 30-amp capacity. There's a 60-amp variety that is a bit larger, about 1 1/2" on each side. The price in the ad above is outrageous- - - -they're on Ebay all the time for about $3.00 each- - - -with connector plugs included.
Search eBay for "relay 15591178"
The best price I see is about $8.00 (no tax and free shipping)
(It will not be Hella brand, but it might be Delco brand).
Search for "Bosch Relay". The generic 30-40 amp relays are going for an average of $2.00 apiece, with the 4 or 5-wire plugs included. I've been using them for years, and the brand name isn't particularly important.
That is not a relay. It is a cream-filled Kraft caramel.
De Licious!
Just bought 10 of them short time ago for stock, $2.70 each with
shipping.
Summit and some other vendors list them for ten bucks each and
the outfit that's pricing them at twenty five is making trying
to make a killing on an item they probably buy for $1-$2 in
bulk.
dg
Denny G
Sandwich, IL
Got dem 12volt 40amp Bosch type relays today, with the socket
and leads as Jerry pointed out.
http://www.pbase.com/dennygraham/image/159119371/original
Bargain at the price.
dg
Denny G
Sandwich, IL
Whom did you get them from, Denny?
Just went to ebay and took the cheapest offer Tim. Came from an
outfit called cecideal out of Redwood City, CA.
dg
Denny G
Sandwich, IL
