9 members (Wally / Montana, padresag, walter74, Wayne67vert, Shaffer's1950, treegrower, TexasFarmTruck, Otto Skorzeny, 1 invisible),
75
Mod | | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 17 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 17 | Have memory lapse. I am converting my '52 from 6v to 12v. Discovered a black box whose purpose is unknown. Need help ID'ing it and purpose. Please, one of you experts !!!! OK. Box markings: 5157C3 Hella 12v 4rd 960388-06 15591178 Also has markings showing switches. Can't draw these on here. Hella website no help. spent 45 min. looking.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It sounds like a relay that did not come stock on your truck. | | | | | Joined: Feb 2011 Posts: 17 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 17 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | It's a simple Bosch-style cube relay that can be used as a headlight relay, fuel pump, cooling fan, fog light, or any other device that needs to be turned on/off remotely. The advantage is in using a small-gauge wire from a control switch to operate a heavy-current accessory without running the current a long way to the dash and back.
Most of the relays with a cube housing with 1" dimensions have a 30-amp capacity. There's a 60-amp variety that is a bit larger, about 1 1/2" on each side. The price in the ad above is outrageous- - - -they're on Ebay all the time for about $3.00 each- - - -with connector plugs included. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Search eBay for "relay 15591178"
The best price I see is about $8.00 (no tax and free shipping) (It will not be Hella brand, but it might be Delco brand).
| | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Search for "Bosch Relay". The generic 30-40 amp relays are going for an average of $2.00 apiece, with the 4 or 5-wire plugs included. I've been using them for years, and the brand name isn't particularly important. Jerry
| | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | That is not a relay. It is a cream-filled Kraft caramel. De Licious!
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just bought 10 of them short time ago for stock, $2.70 each with shipping. Summit and some other vendors list them for ten bucks each and the outfit that's pricing them at twenty five is making trying to make a killing on an item they probably buy for $1-$2 in bulk.
dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Whom did you get them from, Denny?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just went to ebay and took the cheapest offer Tim. Came from an outfit called cecideal out of Redwood City, CA.
dg
