6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#108425 03/20/2002 9:17 PM
When refinishing the body on an old truck does anyone have any tricks to sealing the seams between say the rear fenders and the bedsides or the front fenders and the cab? Is epoxy primer enough or should something else be done. What I am looking at is priming each individual panel, reassembling the truck, then shooting the finish coat. I'm working on a 55 1st series 3/4 ton. Thanks for the help.
Steve
55 1st Series 3/4 ton
#108426 03/21/2002 5:25 AM
Do you want the original "solution" (black fender welt) or a custom "invisible" seam?
If you want fender welt, I'll try to find the website with an article on installing it.
Tim
#108427 03/21/2002 2:26 PM
tclederman, I would be interested in seeing the artical on installation of the welting if you can find it. Thanks
#108428 03/21/2002 5:02 PM
If the fenderwelt is the best method of sealing the seams then that is what I will do, just wanted to hear if anyone has any tricks to preventing future rust problems in between panels. Would be interested in the install website. Thanks for the info.
Steve
#108429 03/21/2002 5:50 PM
we used to prime parts then assemble fenders loosely and paint so top colors are sprayed between body parts when dry install fender welt and tighten parts
i thinkzz traveling along at terminal velocity will soon wear a body out.
i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#108430 03/22/2002 7:26 AM
When I did the Canary, I attached the fender welting to the fender with double sided tape, punched the holes for the bolts and then layed towels between the fenders and the body to prevent scratching while bolted them on, worked real well. Not a scratch and the welting looks great.
#108431 03/24/2002 11:33 PM
http://www.classictruckshop.com/welting.asp
I like Fatfenders method. What type of tape did you use?
Thanks, Tim
#108432 04/27/2006 3:14 PM
Jim & Caroline
