0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 6 New Guy | | New Guy Joined: Dec 2014 Posts: 6 | Looking at buying a 1956 GMC. Looks to be a two ton Farm truck. Not certain on tonnage. Anyway, the Title lists the Model as: A240 Has anyone heard of this model of GMC ? or is that just the model # given by the DMV ? You know how the DMV can be, if thet sayso, then it is trus and accurate. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some about the GMC serial numbers, there is a 250 model, but haven't heard of a 240 model, and the leading letter for '56 was X.... 55-59 GMC shop manualBill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | UnknownLegend,
Might the code be A270?
Do you have a photo of the title?
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | A 270 would be the engine a 300 or 350 was born with if it has a 6cy. 240 and 270 is a common type and the "A" prefix would be normal for the engine. | | | | | Joined: Dec 2014 Posts: 6 New Guy | | New Guy Joined: Dec 2014 Posts: 6 | I was thinking A270 also. It was a farm truck with a flatbed and stake sides. Maybe a type error on the seller's part also. OR Maybe a type error on the DMV's part. I will get a look at the Title on 2/10/15.
Thanks | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | My GMC is a model 370 (in the grille) with a 270 engine.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | |
