0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
Got the cables in for the kick panel vents, but I'm at a loss on how to install them so that they work. My first question is should the vents "Spring" open one way or another without the cables installed? Currently, mine don't spring open one way or another, which leads me to believe there should be a spring; but I'm not sure about this. I have the cables run and mounted, just can't figure out how to mount them to the vents so they can operated correctly.
1955 GMC 100 Series 2
the cables push/pull the vent doors and hold them in any position [full or partially open/closed], nothing 'spring loaded' .... there's a grommet where the cable goes thru and a clamp just inside there to hold the cable sheath, then the coiled end of the cable core goes over a peg on the door - the clamp may be missing - have an assembly manual? section 1 sheets 55.00 and 55.01 show it all
I have the maintenance manual but not an assembly manual.
http://chevy.oldcarmanualproject.com/gmc/5559mm/index.html
inside pass side vent with the flap full open
Awesome, thanks for the photo. Got a feeling I'm missing some parts.
Yep, missing the clip that holds the cable, and that little clip makes everything function right. Thanks again for the help.
red58 - any recommendations on where to buy a clip like the one in your photo? I've now purchased 3 different clips from CI and none are small enough to hold the cable in place. It seems the main way the system works is dependent on the outer cable not moving and you would think installing something so simple wouldn't be such a hassle....
check around with small motor shops, lawnmowers and other power equipt use similar cable clamps - or make your own, just needs to be a piece of metal with a bit of a kink in it, similar to the clamp pieces that hold the choke and throttle cables
Thanks Red. Right after I posted this I found some metal in my took box that will hopefully work. Will let you know the results.
Moderated by  ndkid275, Phak1
