0 members (), 85 guests, and 0 robots.
Topics128,115
Posts1,056,291
Members48,439
#1084113 02/07/2015 4:08 AM
I have been asking lots of questions lately concerning the rebuild on my/my sons '48 Chev Truck. Thank you Stovebolters for the answers. Now. What is the Toe-In setting for a 1948 Chevy 1/2 ton Pickup? Dont know if it matters but she now has 15" wheels and 235/75R15 Tires. She still maintains the original front axel.
It was explained to me by an old tire guy that you wanted about 1/8th inch toe in for bias ply tires and closer to 1/4 inch for radials. The quarter inch toe in seems to work best for my truck with radials.
Thanks guys. She does have radials. The Toe-In is now set on 3/16" and she steers great. And now she is, as Willie would say, "....on the road again".
1/4" toe in with radials is way too much. 1/16" would be the correct setting with radials. At 1/4", they'll feather very quickly.
Bill Burmeister
I would go 1/8" as well, just be sure to check it correctly.
Lift the front tires off the ground and scribe a true center line around the diameter of each one.
Have the truck on level ground and roll it forward at least one tire rotation or more.
Let it come to a stop with out using the brakes or rolling backwards.
Measure the rear of the tire at the the same hight as you do at the front of the tire, and measure as high up on the tire as possible.
Have the same person hold the tape each time and the other read the tape.
This will give as close to a driving measurement as you can get.
Joe
