0 members (),
84
Mod | | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Attached is a link to the picture of the transmission looking up at it from below. How do I determine the fluid level. Do i use the one top left and fill to this hole for level? is the one on the right used to determine the actual fluid level? Thanks Steve http://i1321.photobucket.com/albums/u558/smoloney08/transfillholes_IMG_0913_zps1b44e071.jpg
| | | | | Joined: Jan 2002 Posts: 2,854 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,854 | I believe the upper plug on the left side of your pick is the bearing support retainer plug. Fill plug is the other one, right side lower.
Not owning a 3 speed, I'm only guessing. Hopefully someone else will confirm.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Fill to the one on the right. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Fill 'below' the one on the right on level ground when cold. Poke your little finger in bent at the the first joint, its correct when it just touches the oil. The level will rise when it get hot. Over filling it will cause it to puke oil out the seals.
DG
Denny G Sandwich, IL
