Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
11 members (2-Ton, wvstovebolt, MTD91, Gdads51, Otto Skorzeny, TexasJim50, RaNfLaS, TexasFarmTruck, dt235sd, 2 invisible), 101 guests, and 3 robots.
Topics128,290
Posts1,058,554
Members48,491
Attached is a link to the picture of the transmission looking up at it from below. How do I determine the fluid level. Do i use the one top left and fill to this hole for level? is the one on the right used to determine the actual fluid level? Thanks Steve
http://i1321.photobucket.com/albums/u558/smoloney08/transfillholes_IMG_0913_zps1b44e071.jpg
I believe the upper plug on the left side of your pick is the bearing support retainer plug. Fill plug is the other one, right side lower.
Not owning a 3 speed, I'm only guessing. Hopefully someone else will confirm.
Craig
Fill to the one on the right.
Fill 'below' the one on the right on level ground when cold.
Poke your little finger in bent at the the first joint, its
correct when it just touches the oil. The level will rise
when it get hot. Over filling it will cause it to puke oil
out the seals.
DG
Denny G
Sandwich, IL
