| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 308 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 308 | Hi all,
Been driving my '46 1/2 ton for 30 years now and started to notice a bit of vibration in the driveline in 4th gear. Since I had recently done front and rear motor mounts and inspected the U-joint I began to suspect that something was grounding out to the frame. When I pulled the transmission mount loose I saw that the rubber on it had deteriorated almost completely and that I had possible metal-to-metal contact. I installed the trans mount myself in 1986 (a NOS part), but the truck came to me without one. Out of curiosity I drove the truck without the mount on it (doesn't appear to actually support the trans - more like a brace). MUCH smoother, so I'm thinking I'm right about the grounding issue.
Here's the question: do all of you have the trans mounts on your 41-46 Chevys? I'm going to install the rebuild kit, but I'm wondering if it's really necessary.
David
