0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | what is the way to re-paint a cab corner (due to paint being stripped by STP (different story)). It is painted with Acrilic enamel, i have some paint left (enough to do the cab corner, but not the entire back of cab).
Could anyone help me with the specifics (i.e. how to get rid of the tape line is the main thing)
Thanks a lot Brian K
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | what you want to do is first clean the area really good with some greese remover
Than tape about 6'-8" away from the furtherst edge of the area to be painted. Tape the masking paper down on top of the tape. Now take the masking paper fold it towards the to be painted area. now fold it back with a rounded edge. Covering about 1/4" over the repaint area. Now tape the end of the fold down onto the masking paper.
spray straight dont try spray under the paper. Basically what is going to happen is you get over sprayunder the paper but none or a very little amount of a hard line.
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | Thanks a lot, i will try that (sanding down tonight, try to paint on sunday)
Thanks again, Brian
P.S. NEVER EVER EVER use STP fuel injector and carborator cleaner (when mixed with gas it makes a great paint stripper :mad: )
