| | | Forums66 Topics128,050 Posts1,055,639 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Does anyone out there have photos of the pot metal window frame that attaches to the outside of the cab and holds the rear window in place. I didn't have one on my truck and need to know exactly what I am looking for.
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I can take a picture of mine installed. I am not sure if I have any pictures not on the truck. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I just looked on ebay, there is one on there. They only show the outside ,the inside has drilled and tapped bosses for 10-32 screws. Search under 1941 chevy pickup. Let me know if you still want other pictures. Dave
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Look (on ebay) I put the direct link to the ebay item but it was removed.
I didn't think the 42's had this. Does the opening in your cab have a row of holes all around it? Dave
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | gerrys42, With that login I will take it that you have a 42, they did not come with the cast pot metal frame for the rear window. The rear window area of the cab should have 14 holes in the cab where the frame attaches. The rubber gaskets for these does not come with any holes in them so you have to drill them. If you need a picture of the frame I can email one to you.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | Guys, Although bill of sale and registration states it is a '42 the rear window says something different. That raises another set of concerns. I found two broken frames that might work. Going to make one out of the two (I hope) | | |
