1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1083280 02/02/2015 10:42 PM
Does anyone out there have photos of the pot metal window frame that attaches to the outside of the cab and holds the rear window in place. I didn't have one on my truck and need to know exactly what I am looking for.
I can take a picture of mine installed. I am not sure if I have any pictures not on the truck. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I just looked on ebay, there is one on there. They only show the outside ,the inside has drilled and tapped bosses for 10-32 screws. Search under 1941 chevy pickup. Let me know if you still want other pictures. Dave
1941 Chevy
Look (on ebay) I put the direct link to the ebay item but it was removed.
I didn't think the 42's had this. Does the opening in your cab have a row of holes all around it? Dave
1941 Chevy
gerrys42, With that login I will take it that you have a 42, they did not come with the cast pot metal frame for the rear window. The rear window area of the cab should have 14 holes in the cab where the frame attaches. The rubber gaskets for these does not come with any holes in them so you have to drill them. If you need a picture of the frame I can email one to you.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
Guys,
Although bill of sale and registration states it is a '42 the rear window says something different. That raises another set of concerns. I found two broken frames that might work. Going to make one out of the two (I hope)
