2 members (Hush, delky),
141
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | im in the process of building a 1939 jc 1/2 ton truck and i was wondering if any of you fellas know if the door windows had a frame on them or is it bare glass attached to the bottom rail only.any and all info will be greatly appreciated. | | | | | Joined: Aug 2005 Posts: 277 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 277 | Window glass for 39-40 did not have a frame. 41-46 used a frame. You can use the frame and glass from a 41-46 in your 39 if you want. The glass pattern for 41-46 is slightly smaller than 39-40 to compensate for the added frame. Not certain why they went to the frame in 41 unless it was to avoid glass breakage. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I just last week removed the glass with frames from my '46 half ton project. If you need photos I can post a link. | | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | ok i think i want to use the frame to protect the window from the vibration.and 46sparky please post the link.if everything bolts up with no modification i will be installing that set up. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Been driving my 39 since 1977. The door windows do not have frames, and they have never cracked or broke. They don't rattle either.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Feb 2000 Posts: 5,221 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,221 | '37-'38 did not use frames. The glass is set into the channel with setting tape. With new window weather stripping, the glass will not rattle or chip. Mine seal really good for a old truck.
Joe | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | As requested here are links to photos of the '46 side windows. Here 1 Here 2 | | | | | Joined: Jul 2006 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 36 | You don't really need the frames to protect the glass. I have been driving my 40 since 1998 and have never had an issue with chipping the glass. I think they look a lot better without the frames. | | |
