1 members (2-Ton),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | Yesterday, we removed the front fenders (outer and inner) from my 53 Chevy 3100. When we go to the radiator support, it was wobbly loose, held by only one bolt. Ended up cutting the one bolt with the sawzall to remove the radiator support to find this... http://www.timjharrisphoto.com/53chevy3100/h2b274e7d#h2b274e7dThe missing piece of front crossmember was gone...and has probably been gone for decades. There was one small piece, you can see it in the photo, laying by the shims. I guess I am going to have to weld in a patch and drill the mounting hole for the radiator support. Makes me wonder what caused that.
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | It can be a place where water pools up. And depending on how long it sat outside, it is entirely possible. Never seen one that bad. You are on the right track. Its a very important crossmember. You can always go find another better one, grind out the rivets and re-rivet in a new one. Riveting isn't as hard as people think. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | I would bet that a previous owner had a similar problem as you with the frozen bolt, and used a cutting torch to "remedy" the situation and figured one bolt would be good enough. If the metal is sound on the rest of the cross member, I would weld in a patch and drill a new hole. There appears to be plenty of leaked oil on your cross member to have kept it protected from rust. Carl
| | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | The truck has been in my family since it was new. The hole appears to be broken out, not torch cut. The metal around the hole does not appear that the hole rusted away. It looks more like it was the result of a crack that eventually broke out.
This, combined with some other things I have found, makes me wonder if the truck was in a wreck at some point early in it's life that I don't know about. This is what I have found...
1) The outer corner of the left front fender was at one time fairly seriously crushed, because it was hammered back out, but the finishing body work was never done. Also, the left headlight assembly appears to be a replacement.
2) The hood latch panel is painted blue underneath, the truck has always been red.
3) The lower grill panel is rusted through along two very defined creases, that appear to be places where the panel was bent and then straightened.
4) The front bumper has a slight wave, just left of center, that could be a sign it was bent in, then heated and pulled back out to almost normal position.
5) The grill bars are beaten up, could have been caved in and then sort of straightened back out. More so on the left side of the truck.
My theory is the truck took a pretty good lick on the left front. The impact point (by the height of the fender damage) was about headlight height. This pushed the top of the grill, hood latch panel and radiator support back. The force could have cracked the crossmember, maybe not breaking it out at the time...vibration and movement broke it out over the years later.
For this theory to be true, the hood would have also been damaged. The truck has a solid mint condition hood...perhaps a replacement.
I do have a very vague memory of the truck being worked on in the FFA Ag Shop at the high school. This was when I was a small child, my memory is going to the shop on a Saturday and watching my older brother and his friends mask and paint the truck. This would have been around 1969-70ish.
No one is left who could tell me what happened, so I just have to make my best guess based on what I see.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | You are in the right place Tim. The guys here have alot in common with you. I suggest that doing it right, is the only way, so take your time, ask plenty of questions, and don't take the easy road on anything, and your truck will be something really special!
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Weld her up and drill a new hole. Good to go.
