| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 3 New Guy | | New Guy Joined: Jan 2015 Posts: 3 | I have a 1960 235 truck engine. Replacing rings on one piston. Manual for the 1960 series states "Compression rings in all truck engines are the deep section twist type. This type of compression ring takes its name from its installed position which is cocked or twisted. It assumes and maintains this position for life because the upper edge of its diameter is chamfered." In the specs section the manual states "Upper compression ring: Thickwall Inside bevel, Lower compression ring: Thickwall taper faced scraper". When checking the rings that were on the piston i see both compression rings have the inside chamfer (as alluded to in the manual). My question centers around my replacement ring set, the top compression ring has no chamfer, the bottom compression rings do. Is this going to make any difference? Since i have a complete ring set and only am replacing them on one piston i could use a bottom ring also for the top in order to obtain a top chamfered ring as well if its important? Any advice. My ring set is supposedly for a 1960 era 235 (Enginetech part # R35646) but i believe 1953 and earlier 235 rings are different, perhaps i have a pre 1953 set??? any advice? | | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | If the top ring on your new set has no markings or no bevel on either side of the ring, you can install it either way. If the second ring has a bevel, it should have a marking (sometimes referred to as a pip mark) denoting which side of the ring faces up. I would not substitute a beveled ring for the top ring with no bevel. | | | | | Joined: Jan 2015 Posts: 3 New Guy | | New Guy Joined: Jan 2015 Posts: 3 | thank you for the response. | | |
