Brrrr
place holder
6 members (Thom75, UtahYork, Hanks custodian, Mike B, DennisM, 78buckshot), 142 guests, and 6 robots.
Topics128,271
Posts1,058,416
Members48,485
Got my new cam(cs293) for my 235 amd aluminum cam gear.I have read all kinds of horror stories about heating and trying to hammer it on. What is the best way to install the gear???Some say that pressing it on will gaul it and it might come off.I want to do it right the first time.THANKS for any help.
V
V Offline
I had mine pressed on by the shop that did my machine work. Later when assembling I discovered he left too much gap, I secured the Cam in a supported vice underneath the shoulder of the large #1 bearing and a few strokes of a 2lb sledge and a large socket got the clearance where I wanted.
If I had a press I would have definitely used that method over pounding. You have much more control with a nice slow and steady press.
In either case, proper alignment of the gear to the cam is imperative.
Dave
Cam gear: boiling water (I use cotton gloves inside rubber gloves)
Camshaft nose: slowly dip & remove, dip & remove, then immerse in a safe (rubber? steel?) container of alcohol and dry ice
as far as the clearance, there is a little spacer that goes in there somewhere to give you the proper clearance. Mine didn't have one when I took it apart (either time.) But the fella at the machine shop enlightened me. You may be able to get it together by freezing/heating the pieces, but it might not hurt to have a press ready just in case.
Does the thrust plate have a shoulder that establishes the proper end play? Some do- - - -others don't. If I'm dealing with a non-shouldered thrust plate I use shim stock or a couple of correct-thickness feeler gauge blades as spacers, get the gear as hot as a Propane torch will make it, and tap the gear onto the cam quickly while the hole is expanded. It's virtually impossible to overheat the gear with an LP gas torch- - - -no need to get anal about it!
