7 members (MNSmith, Tyler Watts, porsche, Bill Hanlon, Barnfind49, Stovebolt48, 1 invisible),
102
Mod | | | Forums66 Topics128,277 Posts1,058,456 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | I've been thinking about PCV installation since Denny's thread on how wives react to how trucks perfume a garage after shut down.
If an air filter could be fit into the draft tube, a PCV valve could be mounted to the rocker cover (preferably over the oil transfer fitting to minimize exposure to splashing.) I think that many engines in the 1970's had PCVs in the rocker cover.
This would allow for a shorter PCV tube run and a less intrusive installation - it might look more original.
Any thoughts on pulling the air through the engine "backwards"?
Just wondering aloud.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | I had the same thought and went as far as finding parts. Oil Cap Spectre - Oil Breather Cap Haven't check to see if that oil cap will fit yet. I'd be interested to hear thoughts on this as well | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | If you have a 216, you will have several vents in the valve cover to deal with. I will bet that the valve cover vents are the biggest, if not the sole source of the lovely smell, which I enjoy as much as Hoppes Gun cleaner, and the smell directly extracted from freshly shot ammunition brass. Carl
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | A friend of mine bought a 51 willys wagon and when he got it home he noticed a tuna can hanging from the draft tube with wires with screws mounted to the draft tube and tuna can. He said the owner did not like the small oil/condensation drops on his concrete but said nothing about the smell. I told him to check to make sure he did not put a carbon filter in the tube. Here's a good article. Draft Tube Upgrage
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Apr 2009 Posts: 108 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 108 | ...A few years later PCV was standard on the 261 and optional across the line on the 235. I wonder if the earlier Heavy Trucks of your vintage might have been equipped or could be optioned with PCV, which would mean Factory Parts are out there? | | |
