Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (60steve, J Lucas, NJC, klhansen, TooMany2count, Lightholder's Dad), 150 guests, and 0 robots.
Topics128,277
Posts1,058,451
Members48,490
I've been thinking about PCV installation since Denny's thread on how wives react to how trucks perfume a garage after shut down.
If an air filter could be fit into the draft tube, a PCV valve could be mounted to the rocker cover (preferably over the oil transfer fitting to minimize exposure to splashing.) I think that many engines in the 1970's had PCVs in the rocker cover.
This would allow for a shorter PCV tube run and a less intrusive installation - it might look more original.
Any thoughts on pulling the air through the engine "backwards"?
Just wondering aloud.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
I had the same thought and went as far as finding parts.
Oil Cap
Spectre - Oil Breather Cap
Haven't check to see if that oil cap will fit yet.
I'd be interested to hear thoughts on this as well
If you have a 216, you will have several vents in the valve cover to deal with. I will bet that the valve cover vents are the biggest, if not the sole source of the lovely smell, which I enjoy as much as Hoppes Gun cleaner, and the smell directly extracted from freshly shot ammunition brass.
Carl
A friend of mine bought a 51 willys wagon and when he got it home he noticed a tuna can hanging from the draft tube with wires with screws mounted to the draft tube and tuna can. He said the owner did not like the small oil/condensation drops on his concrete but said nothing about the smell. I told him to check to make sure he did not put a carbon filter in the tube.
Here's a good article. Draft Tube Upgrage
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
...A few years later PCV was standard on the 261 and optional across the line on the 235. I wonder if the earlier Heavy Trucks of your vintage might have been equipped or could be optioned with PCV, which would mean Factory Parts are out there?
