1 members (Steveoreno),
111
Mod | | | Forums66 Topics128,195 Posts1,057,375 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 17 New Guy | | New Guy Joined: Jun 2014 Posts: 17 | Hi, I have a 49 Chevy half ton, with a 235 out of a 57. I ordered a new gas tank and sending unit for a 49. The old gas tank drained out of the bottom, the new one has a plug in the bottom and the sending unit has a sock and pulls the gas from the top. I assume that this will still work, but am looking for some feed back. Should i look at maintaining the gravity feed and get a new sending unit, or will this work? Thanks. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Many people think that this change, which started in 1954, is a better arrangement. Sediment in the tank will not as easily plug the outflow of fuel.
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | If you want. The sender works just fine. Take the plug from the tank. Cap the line from the sender and put a line in the bottom of the tank. Works that way as well. What ever you want.
Steve H
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Went through the same thing a couple yrs ago. The top feed works great w/the stock fuel pump, haven't had any fuel related issues since. Good luck Dave | | | | | Joined: Jun 2014 Posts: 17 New Guy | | New Guy Joined: Jun 2014 Posts: 17 | Great, thanks for the help. I'll hook it up. | | |
