| | | Forums66 Topics128,127 Posts1,056,677 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Just got the rear brakes dissasembled on my 54 1-ton tonight. Can someone tell me what I need to save and/or where I can find a kit with the springs and pins? good news is i think the shoes and drums are useable. one drum has some of the outer weld ring popping off bu im not going to tow anything crazy so i thnk they will be fine napa has rear brake cylinders for $70. ouch. anyone have a better source? | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | found cylinders at chevsofthe40's listed for 3800 but look different. mine has a singe boss on the back and these have two angled at about 45 degrees toward front and rear of the truck with only 1 tapped. springs are piecemeal but i think mine are ok | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | are the backing plate pins the same on 1/2 ton and 1 ton trucks? i see the half ton pins but not 1 ton for sale... | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I have a 1951 3800, which is a pre-Bendix brakes setup (started in 1953?). However you should know that the front brake wheel cylinders are different from the rear. I did notice that when I ordered my rear wheel cylinders from Chevsofthe40s, it was actually the front cylinder but mislabeled in the catalog. I ended up ordering the rear cylinders from Jim Carters. They happen to have a better selection of the hard to find brake parts IMO that you may not find at your FLAPS.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | Thanks for the advice. chevsofthe40's doesnt seem to give much info for specs. I'll compare prices from everywhere and take care to make sure i get the right parts. at one point i read that 3/4 ton rear drum is the same as 1 ton front. maybe theyre messing up 3/4 ton rear vs 1 ton rear. | | | | | Joined: Dec 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 75 | Rock Auto catalog list brake shoes, brake cylinders ,hoses and such for 49 3100 and some parts for 1 ton but not specifically for a 3800. wonder what the diff. would be?
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | As far as I remember,3600 REAR drums are the same as 3800 FRONTS. steve sr. | | |
