6 members (Millenimech, Gib70, Hotrod Lincoln, Steelonsteel, Gray_Ghost, 1 invisible), 149 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#108209 12/19/2002 8:57 PM
I have a 46 truck grill that was rechromed sometime in the past. The chrome is in good condition BUT there are numerous small (1/4") cracks around the perimeter. Ideally I would weld these fractures but the chrome would be ruined. Is there some compound, epoxy, something, I could apply from the back side that would lend some structural integrity to these fractured areas?
#108210 12/22/2002 6:08 PM
ive had prety decent luck with j.b. weld.Iused it on a craked crank case on the kids atv.its held good through 2 years of abuse.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#108211 12/22/2002 6:30 PM
Thanks Slow Rider
I've never used j. b. weld. I'll give it a try. smile
