5 members (37 GC, Otto Skorzeny, Ponchogl, 2 invisible), 156 guests, and 1 robot.
Topics128,147
Posts1,056,805
Members48,454
Have a '53 chevy pickup that has a 10 bolt GM rear end out of a 68 firebird setting under the stock truck springs. Sets too high and the springs look too narrow for the spring perch/pads on the axle. Any thoughts on lowering 2 to 4 inches with out getting elaborate on the replacing the springs?
You might try mounting the axle over the springs, rather than under. That should drop it about the amount you're after. The original rearend was mounted that way, as well.
Bill Burmeister
I guess I miss spoke, the aprings are under the axle.
3B Offline
Hy fore's53, you could try putting lowering blocks between the axle and spring you could try different thicknesses until you get the look you want, hope that helps.
are the Posies lowering springs a good option?
Lowering blocks are a lot easier and cheaper.
Please explain to me what a moderate lowering block has to do with scrub line?
The scrub line is measured from a constant, rim to ground surface?
Would love to understand this better.
Thx-
1947 GMC Truck 5 window, Long Bed
2008 Corvette Roadster
2008 Harley Davidson FXDL
2011 F150 Ecoboost 4X4
2015 Subaru Outback AWD
"only the strong survive"
Cthe,
scrub line would remain constant between rims and center pumpkin, but what Hotrod John is saying is that as rear moves "up" compared to frame, fenders, and other things that they can become lower than the scrub line that is defined by the rims. Now you have exceeded the scrub line and a flat tire can be significantly more damaging than just replacing a tire.
R-Bo
1966 GMC 305V6 in the family
