6 members (Peggy M, kades51, fonz8261, Otto Skorzeny, 55shaker, tclederman), 96 guests, and 1 robot.
Topics128,132
Posts1,056,386
Members48,441
I have a 49 chevy 3100 and it's been converted to 12 volt to the point of running etc and fuse box. Does the bulb fittings have to be changed in order to run 12 volt bulbs or head lights? Does anybody have a chart for 6v to 12v bulbs and headlights?
Thanks in advance,
Paul
1964 impala ss
1949 chevy 3100
The bulb socket has to match the bulb base.
Here are some 12v - 6v bulb/base equivalents.
Yeah i done some searching but that says 54 so i wasn't sure if it applied to my 49 or not...so it does? What about headlights? I also seen where the fittings take both 6 and 12 volt bulbs so im good there.
1964 impala ss
1949 chevy 3100
If 54 and 49 use the same bulbs then these headlight part numbers should work. Can anyone verify?
#6014 (50amp low/60amp hi). The 12v halogen bulb is #6024.
1964 impala ss
1949 chevy 3100
nevermind good info went and bought new slyvania halogen #6024 and they work GREAT! Some very good info on this site! smile
1964 impala ss
1949 chevy 3100
