| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | I have a 49 chevy 3100 and it's been converted to 12 volt to the point of running etc and fuse box. Does the bulb fittings have to be changed in order to run 12 volt bulbs or head lights? Does anybody have a chart for 6v to 12v bulbs and headlights?
Thanks in advance,
Paul
1964 impala ss 1949 chevy 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Yeah i done some searching but that says 54 so i wasn't sure if it applied to my 49 or not...so it does? What about headlights? I also seen where the fittings take both 6 and 12 volt bulbs so im good there.
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | If 54 and 49 use the same bulbs then these headlight part numbers should work. Can anyone verify?
#6014 (50amp low/60amp hi). The 12v halogen bulb is #6024.
| | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | nevermind good info went and bought new slyvania halogen #6024 and they work GREAT! Some very good info on this site!
