2 members (crenwelge, 1 invisible), 181 guests, and 4 robots.
Topics128,196
Posts1,057,395
Members48,469
Q
Q Offline
Hi, I have a 49 Chevy half ton, with a 235 out of a 57. I ordered a new gas tank and sending unit for a 49. The old gas tank drained out of the bottom, the new one has a plug in the bottom and the sending unit has a sock and pulls the gas from the top. I assume that this will still work, but am looking for some feed back. Should i look at maintaining the gravity feed and get a new sending unit, or will this work? Thanks.
Many people think that this change, which started in 1954, is a better arrangement. Sediment in the tank will not as easily plug the outflow of fuel.
If you want. The sender works just fine. Take the plug from the tank. Cap the line from the sender and put a line in the bottom of the tank. Works that way as well. What ever you want.
Steve H
V
V Offline
Went through the same thing a couple yrs ago. The top feed works great w/the stock fuel pump, haven't had any fuel related issues since.
Good luck
Dave
Q
Q Offline
Great, thanks for the help. I'll hook it up.
