Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Oswald, Sjm, UtahYork, Stovebolt48), 156 guests, and 4 robots.
Topics128,278
Posts1,058,457
Members48,490
#108150 05/14/2003 4:47 PM
Junior Member
Junior Member
I took my '52 half ton apart over a year ago. Now I am painting and ready to put it back together. Does anyone know if a fender to cab seal (gasget)is required? I think mine had a rubber-like gasget between the fender and cab.
Also, is it better to paint the parts before putting everything together?
Will I ever get my truck done???
http://www.3cware.com/myoldchevy.cfm
#108151 05/14/2003 5:01 PM
Yes, and they are available from probably all the vendors. Truck Shop calls it "anti-squeak", and charges $10. Although the picture does not show a piece between the fender and the cowl, I recall when I took mine apart there was gasket there.
#108152 05/14/2003 5:02 PM
OldChevyLover,
Yes, there is fender welting between the front fenders and the cab.
Yes, it is better to paint parts before putting them back together. It is also better to "dry fit" the repaired body parts before painting them.
Check out this link for a technique for installing fender welting (I have never used this technique - maybe someone else has and will tell us how well it worked out).
http://www.classictruckshop.com/welting.asp
Fender welting can be purchased from most restoration parts suppliers (years ago, I got some at NAPA but it was many year ago).
Good luck,
Tim
