2 members (1955 1 Series, Sjm),
152
Mod | | | Forums66 Topics128,278 Posts1,058,457 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Thanks, is there one out there? or is replacement of the cross member the only route?
| | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | DADS50, which Disk brake kit did you purchase and are you using a power master cylinder? or just a dual one? if not power how much better does your truck stock with disk brakes up front over the drum with the dual master? Thanks Steve | | | | | Joined: Jan 2013 Posts: 2,239 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,239 | hey buddy, I have the CPP one that bolts to the frame. I have not connected it yet, but it is supposed to be direct link up dual master cylinder.
Chris | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | DADS50, which Disk brake kit did you purchase and are you using a power master cylinder? or just a dual one? Not using the booster. I used the P.O.L. Kit Manual master cylinder I'm happy with the brake performance But I cannot compare with the booster set up because I have not driven a truck with it. The disc set up was a improvement over the drums on my truck. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Im with Dads50 on this one. No need to do anything but bolt it right up. Pics of my setup on http://devestechnet.com/Home/MorePixI didn't go with the booster and I do not know if that was a good or bad thing yet. I wont know for awhile. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I'm the opposite of Dad. My 48 came with a big booster (like in first post) and it will stop on a dime...all drums, almost too sensitive. I've never driven an old truck without a booster, but modern folk seem to complain a lot about stopping from highway speeds. That said, Deve and Dad don't seem to have an issue. Deve's pretty darn particular (sorry Deve), so if he's good without it, I'd tend to lean that way, and not go through the hassle of a custom install.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | My 1950 3600 was truly all bolt on. At this point filling the mc is a pain but I will soon fix that too. I did see a noticeable improvement with the dual mc. I did replace all brake hardware (except drums) along the way along with lines.
Tim | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Thanks all for the information. One more question. POL or CPP for parts? POL lists their master cylinder as 7" CPP at 8", if there truly is a 1" difference POL would be the way to go as it is tight under the truck as we all know. I haven't completely decided yet but I figure if i'm buying and replacing everything but the rear brakes whats a little extra installation time as the cost difference is only $200 to go with the power master. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | That kit will not fit without modifications. that kit will require at least one modification on a 1950 3100, (The O.P.'s question) the transmission cross member will have to be modified or relocated. | | |
