1 members (NJC),
78
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | I have a 1950 1/2 Ton Chevy PU.
I bought a new door lock and key for the passenger side door. The assembly manual shows that the lock is secured by a spring clip that slides through a slit in the door under the rubber weatherstrip.
Does anyone know where I can get one? I can not find the original.
Thank you. :confused: :confused: | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Any of the vendors that sell used parts could help you, Jim Carter and American Classic come to mind. I am not fond of Heavy Chevy, I think they cheated me, so do not recommend them. If you want a great deal, I will pick one up for you on my next trip to the junkyard, but it is quite a ways from me, I am planning on going out on the 5th of September with a friend. Remind me closer to then if you want this, email me privately, [email protected]. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | An ad in the Swapmeet section will locate that part no problem  | | | | | Joined: Jul 2000 Posts: 23 Member | | Member Joined: Jul 2000 Posts: 23 | Those "HELP" red packages at Pep Boys and other auto part stores include the spring clips. I call them Omega clips.
57 3/4 ton rat 66 C-10 panel 350 200R4 3.07 axle 68 C-20 dump runner, 250 4spd, 4.11 82 Camaro, 305, THM-200-R4 84 Monte Carlo, 350, TH350 EVERETT, WA
