5 members (51sub, walter74, Gdads51, MickeyP, Chip O), 67 guests, and 2 robots.
Topics128,041
Posts1,055,593
#1080989 01/23/2015 2:17 PM
What do you guys recommend I use for steering box fluid in my '42 1/2 ton?
Ex Hall Monitor
Ex Hall Monitor
John Deere corn head grease works well. Any 'self leveling' grease will be OK. Don't use chassis or bearing grease.
I have had good results with is product.
http://www.penriteoil.com.au/products.php?id_categ=14&id_products=90
John G
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
John G.
From whom did you but the Penrite Lube,
when did you buy it, and
what was the cost?
They sell it for a good price, $15.75 for 500ml.
Much more expensive than the price of any brand or corn head grease.
Restoration Supply Company has an impressive variety of hard to find products/parts.
That's cuz their located in a high rent district Tim, Escondido, CA.
But, I bought 2 jugs of Penrite back in '09 when I rebuilt
mine and another steering gear and I think I got it from them.
Pretty sure they are the only game in town when it comes to
importing it. I'm very surprised that out of all the US
petroleum companies that not one is producing a light self
leveling grease.
http://www.pbase.com/dennygraham/image/115320139
It was about ten bucks a jug back then so fifteen bucks
doesn't surprise me.
The Penrite did flow the best in that slump test I did, JD
corn head came out second but was a bit thicker than the
Penrite.
I think if you added a little more hypoid grease to the JD corn
head grease and mixed it up in your wife's blender while she's
out, that you'd have about the same consistency as the
Penrite. Whether it would separate after setting is something
that is worthy of a little test. Might just do that after I
finish with aging the E-10 samples that I bottled up last year.
Denny Graham
Forever Curious in Sandwich, IL
Denny G
Sandwich, IL
I'll use a corn head grease (the price is right), Denny
I think it is is one grade thicker (NLGL0) than the GM grease (which is not available) and I think that the Penrite grease matches the GM spec (NLGI00).
Nonetheless, I'll read with interest (and learn from) the results of any test you carry out.
I posted this a hunert times before. But when I started out
working in the Chevy dealership back in '59 my first job was as
a greaser. Did lub jobs, dealer trades and shuffled cars around.
We checked and topped off if needed, the steering gears with the
same stuff that went in the rear end and shifter box----hypoid
grease. Did the same thing when I worked in the two Sinclair
service stations before I worked at the dealership.
Yeah, grease compound settling test, just what I need, another project.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
