2 members (KEVINSKI, JW51), 79 guests, and 2 robots.
Topics128,024
Posts1,055,390
Members48,422
#108086 03/26/2005 5:19 AM
O.K., I probably know the answer, but gonna ask anyway. After all these years, got a small sandblaster for my birthday! Is it possible to use a particular media that will remove paint, yet not etch glass if not aimed directly at the glass? Thanks.
#108087 03/26/2005 5:51 AM
yes, you know the answer grin you think the little home unit will throw anything other than sand? just make sure you mask the glass properly - accidents happen
#108088 03/27/2005 5:53 AM
I Thought so, thanks!
#108089 04/03/2005 10:00 PM
Recently I have seen walnut shells and baking soda as blast media. Also there are different grades of blast media to address the type of material you are removing and the type and thickness of the material it is attached to, ie steel, aluminum, stainless, plastic etc. Check Eastwood's online catalog. I just received their spring catalog and it had a lot of information regarding blasting equipment and blast media.
#108090 04/16/2005 5:32 AM
Thanks LILRED66, I will.
