3 members (Otto Skorzeny, RoadsScholar, UtahYork), 293 guests, and 4 robots.
Topics128,164
Posts1,057,079
Members48,463
Hi-
My 3600 P/U has wobbly steering, requires lots of correction and occassionally I struggle to keep her in a straight line. Very shifty and Im really afraid I'm going to veer into on-coming traffic.
Ive been told the steering boxes are often the culprit.
Three Questions:
1) Will a new steering gear box likely help?
2) Is gear box replacement a difficult job? Im an average home mechanic with no fancy tools.
3) I hear about king pins creating steering trouble - is that more often a problem with these trucks?
Thanks in advance for steering me in the right direction!
Ron A
I would address the possibility of the steering box being bad for last, since it is the most time consuming task if a rebuild is necessary. They can be rebuilt. No need to buy a replacement usually.
You need to check all of the other steering components first.
King pins.
Wheel bearings.
Tierod ends.
Pitman arm-to-steering arm joint(at left spindle).
Leaf spring shackle pins.
Old bias ply tires will also cause auto-tracking in minor ruts in the road
Carl
Hello Ron,
Similar question/advice was posted in an earlier thread.
Nonetheless:
1. Maybe. Have you adjusted the steering as described in the Shop Manual? How good are your other front-end parts?
2. You'd most likely have to clean off a lot of grease and unbolt about 4 large bolts between steering box and frame, and remove the steering wheel, and remove the bolts/clamp that hold the steering column to the dash. The procedure is described in the Shop Manual. A rebuilt steering gear assembly would cost around $350.
3. More often than what? King pins wear out and are commonly found to be loose in these old trucks, which were poorly maintained after their first 10 years of existence/service. This is easy to diagnose (Shop Manual). If the axle cannot be serviced and/or the steering knuckles/spindles cannot be serviced, this can be a challenging repair.
Do you have tools and experience in doing mechanical work on cars/trucks?
Do you know a garage that can/will work on an old vehicle?
Do you have a Shop Manual?
