1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 61 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 61 | O.K., I probably know the answer, but gonna ask anyway. After all these years, got a small sandblaster for my birthday! Is it possible to use a particular media that will remove paint, yet not etch glass if not aimed directly at the glass? Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, you know the answer  you think the little home unit will throw anything other than sand? just make sure you mask the glass properly - accidents happen Bill | | | | | Joined: Dec 2003 Posts: 61 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 61 | | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Recently I have seen walnut shells and baking soda as blast media. Also there are different grades of blast media to address the type of material you are removing and the type and thickness of the material it is attached to, ie steel, aluminum, stainless, plastic etc. Check Eastwood's online catalog. I just received their spring catalog and it had a lot of information regarding blasting equipment and blast media. | | | | | Joined: Dec 2003 Posts: 61 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 61 | | | |
